FL15 looks normal. You can take it off, rig it up and measure it with NanoVNA. It's a coil, two coils with ground in the middle. Unless FL15 pin to ground does not measure as coil, then it is a capacitor, but the marking say L, so I suspect a coil.
All these 3 components should have same exact values. Measure FL15, and use two small coils (or caps if it is a cap) in place of one.
