Author Topic: Repair bricked Rigol DS1052E  (Read 2801 times)
Offline Zaq
« on: June 13, 2015, 09:18:34 pm »
Can some one help me out to get my Rigol DS1052E working again?
Did the 100MHz hack, that worked fine.
Than i want to upgrade firmware and the scope is compleet
dead. |O
Only white screen, nothing else.
Can some one give me instructions what to do.
I dont have a jtag op external programmer.
With regards,
The following users thanked this post: ivi_yak
Offline bigone5500
Re: Repair bricked Rigol DS1052E
« Reply #1 on: June 14, 2015, 01:21:22 pm »
I found this thread: https://www.eevblog.com/forum/blog/the-dark-side-of-the-rigol-hack-bricked-scope-how-to-fix-it/
The most common problem is totally dead scope after unsuccessful firmware "downgrade/upgrade". The only way to recover it is to reprogramm the flash chip (Spansion S29GL064N90TFI04) either via BlackFins's JTAG interface or in external programmer. There is very important part inside the flash with the factory calibration data, which is unique to every unit. These data has to be preserved in a new flash image for proper operation.
« Last Edit: June 14, 2015, 01:24:15 pm by bigone5500 »
Offline Zaq
« Reply #2 on: July 18, 2015, 06:44:57 pm »
I got in contact with Drieg.
Sent the main board to him and he repaired it verry well.
I'm verry happy to have a working scoop again. :-+
Drieg thank you verry much.
