Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Repair broken ZIF socket for 20624 ribbon cable
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Repair broken ZIF socket for 20624 ribbon cable (Read 1002 times)
GreyArea
Contributor
Country:
on:
March 10, 2021, 03:06:06 pm »
So, er, yeah. Oops
While "fixing" my dads laptop I seem to have broken the ZIF connector for what appears to be a 20624 ribbon cable. I'm a little , unwilling to dismantle it further if I can avoid it.
I have a solder hot air gun, and if I can identify the socket I'd consider replacing it. I also thought about trying to solder the thing in there or glueing it, but thought I'd ask for help identifying the part and to get some advice.
Thanks,
Logged
samnmax
Regular Contributor
Country:
Re: Repair broken ZIF socket for 20624 ribbon cable
Reply #1 on:
March 10, 2021, 03:20:35 pm »
I would just jam it in there and tape it over...
Perhaps with a thin layer of material added to press the ribbon against the pins. It's just 4 low power pins for the power button and LED, right?
Logged
coromonadalix
Super Contributor
Country:
Reply #2 on:
March 10, 2021, 03:23:43 pm »
use hot air station to remove the connector and put a new one with the needed flat cable ptich, you have to check if the contacts are the bottom or top ones
seems to be the bottom model
Patching and fiddling with it may end in bad contacts or problems
Logged
GreyArea
Contributor
Country:
Reply #3 on:
March 10, 2021, 03:49:38 pm »
Quote from: coromonadalix on March 10, 2021, 03:23:43 pm
I don't suppose you any clues as to model number of the socket do you? So far I have it as a 1mm pitch 4P FPC connector of some kind. I've ordered a candidate off fleabay, but some certainty would be nice.
And yes, agree that the other solutiont are a bit "How you doing?", replacing the socket seems best.
Last Edit: March 10, 2021, 04:07:42 pm by GreyArea
Logged
perieanuo
Frequent Contributor
Country:
Reply #4 on:
March 11, 2021, 07:45:12 am »
you can remove isolation of your flat ribbon, remove connector and solder the ribbon on the pcb directly, you have the other side of the ribbon with connector for ddisconnecting the pcb's.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
