Author Topic: [Solved] Repair / DC 3.3V 2.5A Open Frame Power Supply / Network Switch  (Read 9133 times)
Offline Bushougoma
Re: Repair / DC 3.3V 2.5A Open Frame Power Supply / Network Switch
« Reply #50 on: March 23, 2017, 11:11:32 pm »
I've used Meanwell before they make quality supplies for a reasonable price.
If you stick with the known brands you'll be ok just stay away from the dirt cheap no names they will likely have crap caps and no EMI filtering.
The following users thanked this post: xan
Offline Phil_Tech
« Reply #51 on: August 30, 2017, 01:07:32 am »
I've just repaired one of these PSUs, the output was at 2.7v. Replaced C3 10uF 50v (the little one just above the 8pin controller chip A6351). Now output is back to 3.3v. The electro didn't look bad but did not register on my ESR meter.
Offline xan
« Reply #52 on: June 27, 2018, 08:22:22 pm »
Well done guys!  :) thank's everyone for support! fixed with a new cap 50v 22uf! device back to life! :-+ :clap:
