Author Topic: Help to identify 8 pin IC  (Read 2023 times)
Offline nikolayuTopic starter
« on: December 08, 2023, 10:47:31 pm »
Hello everyone.
I need help identifying and replacing a burnt IC.
The device is a Garmin dezl 870 with a charging problem (not charging). I opened it and I see that one IC is burnt so I can't read what it is so I can replace it.
Does anyone know what model it might be?
Online ArdWar
  • Country: sc
Re: Help to identify 8 pin IC
« Reply #1 on: December 09, 2023, 12:44:20 am »
The following users thanked this post: fzabkar, nikolayu
« Reply #2 on: December 13, 2023, 06:45:41 pm »
Tnx for info.
I just saw that on other side I have also burnt component (I think its ag1 like the one on left side), but I'm unable to find what is it. Do you know what part is that?
Offline coromonadalix
« Reply #3 on: December 13, 2023, 07:13:05 pm »
seems the same since we see a small bit of the numbers on the burnt one ??
« Reply #4 on: December 13, 2023, 07:25:56 pm »
It's look like the same but I don't know what component AG1 is so I can order it and replace.
Online fzabkar
« Reply #5 on: December 13, 2023, 07:57:11 pm »
« Last Edit: December 13, 2023, 08:03:48 pm by fzabkar »
« Reply #6 on: December 13, 2023, 09:34:20 pm »
give me this loll  but not an sot-323  6 pins ??
AG1
GA4A3Q
NEC Electronics
SOT-323
NPN transistor
Sw, 60V, 100mA, 200mW, R1/R2=1k/10k
i would vouch for the previous answer ???
  if you have an ohm meter or diode test ...
Online fzabkar
« Reply #8 on: December 13, 2023, 10:32:50 pm »
This is 3 pin.
One from picture is 6 pin
here are the readings both diode and ohms
Online fzabkar
« Reply #9 on: December 13, 2023, 10:41:37 pm »
Pins 2 and 3 look like Ground and Vcc, respectively. If so, then that would invalidate my previous guess.
« Last Edit: December 13, 2023, 10:43:54 pm by fzabkar »
Offline DavidAlfa
« Reply #10 on: December 14, 2023, 05:13:57 am »
"aG" is 74AUP1G332GW, but it seems very explicit about the "A" in lowercase.
« Last Edit: December 14, 2023, 05:15:57 am by DavidAlfa »
« Reply #11 on: December 15, 2023, 06:05:52 pm »
Here additional details that I found.
Its something with USB pins.
I found AG1 at USB port.
Online fzabkar
« Reply #12 on: December 15, 2023, 08:23:46 pm »
It looks like it must be an ESD protection component, perhaps a TVS diode array?
Could it be something like this?
https://www.farnell.com/datasheets/89316.pdf
« Last Edit: December 15, 2023, 09:07:29 pm by fzabkar »
Offline DavidAlfa
« Reply #13 on: December 16, 2023, 06:46:19 am »
Yeah totally seems the case.
