I think we've all done some idiotic things while performing a repair.
I remember I was fixing a Fluke 8920A thermal converting voltmeter, turns out it had a bad filter capacitor. Okay so easy fix, fired up the solder sucker, slapped a new cap in and whammy it was working again. Ran some sanity checks and looked to be in spec. Then I went to put the thing back together. While investigating the meter I had removed some of the screws holding one of the internal boards so I could check under it for more electrolytic capacitors. As I was going to reinstall the screws one fell off the tip of the screwdriver and landed directly in the meat of the circuit. Turns out I had forgot to turn off the voltmeter... Upon realizing that fact, I turned it off and quickly pulled the screw out and reinstalled it. After firing it up again, I found it didn't measure correctly any more. Furthermore, I killed the one part that was unobtainum: the custom Fluke thermal converter IC. It's dead Jim. Angry, I picked up the whole thing and threw it in the trash.
More recently, I was refurbishing a plasma cleaner. The unit had a ratty power cord with a jacket so worn that the inner conductors were exposed. So I figured it was time for a new one. Grabbed my dikes and proceeded to snip the cord off near the strain relief. Turns out I had forgotten to unplug the damn power cord while testing the unit! God damn shit show proceeded to unfold as I cut through the cord. Interestingly, the breaker didn't trip during my hazardous short circuiting of the AC mains. Instead I plasma torched a notch in my cutters and coated the fuse holder and strain relief in a nice layer of copper courtesy of the plasma cloud fueled by the metallic vapor explosion. Turned a five-minute job into an hour long cleanup and search of a new strain relief. I also threw my newly modified dikes away in a walk of shame, I couldn't look at them and not think about how stupid I was.
Moral of the story, make sure you turn things off / unplug the power cord when performing any reassembly or disassembly.
