Author Topic: Repair Fluke 189 LCD.  (Read 1025 times)
Offline RxnWreckerTopic starter
« on: June 03, 2020, 02:56:20 pm »
I have a Fluke 189 with a cracked LCD.  The LCD still functions over a portion, but the top right corner where the damage occured does not display (see photo).  I assume this is irreparable and must be replaced but maybe I'm wrong?  If so, I appreciate advice from whatever wizard knows how to do something like that.
Odds are though I will need to replace the screen.  I have searched unsuccessfully for a replacement part.  The Fluke manual doesn't give me a part #, but I saw a similar post on this forum with 688181 listed as the part #, so I believe that is it.  I could use help finding it, if anyone has advice, or if anyone is selling it looks like I'm buying.  Also, I have little experience with LCDs, is there any cross compatibility among LCDs ie can I possibly find a screen made for something else but with similar specs and use it?
Thank you, hope someone out there can help.
PS I tried calling Fluke to get the part, but they haven't been any help as the part is obsolete.  I'm pretty sure that the part # is correct then, but the 2 guys on the phone seemed to know even less than I do on the topic.
Photo of LCD:
http://autoforums.carjunky.com/photos/pic/533pA4lm/1620.jpg
« Last Edit: June 03, 2020, 02:57:52 pm by RxnWrecker »
Offline rvalente
  • Country: br
Re: Repair Fluke 189 LCD.
« Reply #1 on: June 03, 2020, 03:12:12 pm »
Well, I'm very sorry to see a nice fluke in this situation...
However, the 189 seems to be a a platform shared with 87IV, 89 IV AND 187 sow these could be donor parts if you happen to find a blow unit.
I've found some with help of google around 40usd, please check:
https://www.ebay.com/itm/FLUKE-LCD-Display-Fluke-87-IV-89-IV-187-189-/193313123423
https://electronictest.equipment/collections/fluke-parts-new-fluke-lcd-displays-6/products/fluke-189-lcd-display-1
https://articulo.mercadolibre.com.mx/MLM-778960530-lcd-fluke-189-_JM#position=1&type=item&tracking_id=fd2f052f-0d47-47fe-9681-7d41f2641024
I may check in Braziliam repair center for you, but they always ask for unit serial so I would need it.
« Reply #2 on: June 03, 2020, 03:20:31 pm »
Is the unit serial number written on the back under the barcode?  If so its 94060200.  Thanks for the links I am checking them out staring now.
Offline coromonadalix
« Reply #3 on: June 03, 2020, 04:40:00 pm »
« Reply #4 on: June 03, 2020, 07:36:23 pm »
Thank you everyone for the replies, I am going to try and buy it and see if it works, I'll post a pic once it's all shiny and new.  :-+
