Hi, i have the SkyRC imaxB6AC V2 and due to faulty usb cable had blew it off.
But I managed to replace the TD1534, the 78M05 the mcu MA84G564AD48 and LCD Screen.
I also managed to connect it with USB and by connecting GND to SDA signal and reseting it put the firmware upgrade Β6ACV2_V1.13
After that the charger boots but stays at first logo screen which says SKYRC IMAX-B6AC and nothing happens, no beep no battery menu.
Nothing else in circuit is at fault, can you please tell me why not working?
Do i need other firmware to install or mcu needs more info to load???
I bought the MA84G564AD48 on ebay and i have tested 2 chips with same result.
Thank you in advance
