Author Topic: Repair Hameg HM1004-2  (Read 3704 times)
Offline jbnlTopic starter
« on: May 01, 2016, 12:25:59 pm »
Goodday All,
I have here a Hameg scoop HM1004-2 wich was working fine, suddenly the time/base went running automatic to lowest value and keeps on lowest value.
Also it is not possible to change anything with the rotary's on the front or change from dc/ac.
But the strange thing is that when i turn on the scoop i get no keyboard error and no mainboard error.
I can switch to component tester and back, but in scoop mode i can't change anything.
I have checked all the voltage's on the mainboard/psu/front board and all are correct and within spec's.
Has anybody had this before or maybe a idea where this can come from ?
Re: Repair Hameg HM1004-2
« Reply #1 on: May 01, 2016, 12:31:19 pm »
Welcome to the forum.
Sounds like a timebase problem, there's many here that can help, what service tools and instruments do you have to complete this repair?
Please also provide a link to the Service manual you will use so that we are all on the same page.  ;)
« Reply #2 on: May 01, 2016, 12:49:55 pm »
I have received the service manual from the tech department from Hameg Germany.
Where can i drop it ?
I hope indeed that i will repair it because i like the scoop very much.
I have a second scoop/function generator/multimeter on my workbench.
« Reply #3 on: May 01, 2016, 09:04:55 pm »
Any of the manual repositories in this thread are good:
https://www.eevblog.com/forum/repair/repair-documents-and-links-sticky-me-please-mods/
My favourites:
http://www.ko4bb.com/manuals/
http://www.ebaman.com/index.php/remository
Online nctnico
« Reply #4 on: May 01, 2016, 09:07:59 pm »
I'd check the contacts of the rotary encoder and look at the signals. If the timebase goes to one setting it means there is a contact issue somewhere. Maybe it is just a matter of reseating the cables. Start with the simple things and don't assume the worst.
« Reply #5 on: May 02, 2016, 05:19:29 am »
Goodday,
I have check the signals from the rotary and even exchanged the rotary encoder with a other rotary encoder but does not solve it.
The signals from the rotary are oke and the voltage's on the mainboard/front also oke.
The strange thing is that non of the front buttons works but i don't get any errors when starting up the unit and also no keyboard error.
No keys are "hanging" and all the rotary's are oke with the signals.
Offline RajGowda
  • Country: ae
« Reply #6 on: January 30, 2020, 07:10:30 pm »
 Can you please send me the HM1004 oscilloscope service manual as I have problem in the Oscilloscope
Thanks & Regards
