Author Topic: Repair help for a KSGER T12 Soldering Station  (Read 1248 times)
Offline Paul-HTopic starter
« on: April 20, 2021, 03:30:38 pm »
Hi all
Hope this is in the correct section for this, perhaps a MOD could move it if not.
I have one of the KSGER T12 style Solder stations, in the handle there is a Thermistor used to read the handle temp but mine has never worked, I finally got around to checking it and found that the reason its never worked is because the Thermistor is snapped in half.
Anyone with one of these stations do you know what value the Thermistor should be so I can fix it.
It looks like it was a MF58 3950 type but they come in 10 different values from 1K ohm to 10M ohm, anyone know what the correct value should be.
Thanks
Paul
Offline tunk
  • Country: no
Re: Repair help for a KSGER T12 Soldering Station
« Reply #2 on: April 20, 2021, 06:48:23 pm »
Excellent most helpful.
10k is needed
