Hi!
I got an Keithley 2000 from ebay. Date codes look like somewhere around second half 2004, PCB has 2015 on it, front 2010.
Everything is *very* clean, nothing looks used, no dust, no spiders, it still has the protection film on the display. On the outside, ok, someone really didn't like it. Perhaps it was rack mounted and removed by a physically challenged or more experienced in agriculture.
Problem: it only displays "No Comm Link", no beep, no smoke, nothing. As far as I see this message is displayed by the display itself, so the base unit seems to be dead. Wiggling the connector did not help.
I poked around in power supply section, not sure where to look for.
CR 102 gives 49 V, CR 103 10.2 V, U144 5 V, U125 15 V.
U119 gives -9 V and is hot (ok, warm. I touch it and feel the temperature.). As far as I see in repair manual it shall give -15 V.
Before starting to poke more, anyone has a suggestion where to go for?
As far as I see, the caps look great. No swell, no fluids, nothing. Clean as can be.
Thanks!
