Author Topic: Rohde & Schwarz SMIQ03B with Error 313, Error 180 Calibration failed and Erro183  (Read 730 times)
Offline lcharmanTopic starter
  • Country: hk
Hello
I have a R&S SMIQ03B with the error in the subject.
Four errors 313 Calibration memory lost shows;
1. - LEV PRESET, 2. - VECTOR MOD, 3. - LEV ATT and 4. - ALC OFF MODE = TABLE - run internal calibration
I perform the internal calibration.  3 Errors 180 occur 1. Calibrate ALL Failed; execution stopped, 2. Calibration failed; Level Preset and 3. Calibration failed; Vector Modulation.
During the internal calibration:
Error: reference voltage oot (6.9...12.0V) occurs for Vector MOD calibration.
Error: No IQCON no convergence occurs for LEV PRESET calibration.
I run the learn table in LEVEL>ALC, error: CW: ALC_ON Voltage oot occurs.
I am not sure if it is the problem from IQ modulator or IQ Converter.
Every advice is welcome :)
Offline oe7dbhnew
  • Country: at
    • HiDes technik & OE7DBH
Hi Gays    .....Happy new Year
I have almost the same problem, I get the message:
Error:   nominal Level oot
Error 180   Calibration failed    Level preset
Of course, according to this, the measured output power is by no means the same as the value shown on the display,
e.g. the absolute output power is just 3mW despite the +16dBm setting.
I would also be grateful for some good information that will lead to success.
Vy 73 de OE7DBH
Darko
Offline wn1fju
For what it's worth, we had one of these signal generators at work which threw all kinds of errors.  Turned out it was simply that the internal battery was dead.  Try replacing it first.
Offline oe7dbhnew
  • Country: at
Thank you for answer and Happy new year
Yes, I have already ordered it (6 batteries, 2 each for both devices - i have two SMIQ ) and will see if the errors disappear.
The lower one shows no errors after internal calibration until switched off-on again - probably a memory battery problem.
PS.   Rene´ danke fürs Info
« Last Edit: January 02, 2025, 04:34:07 pm by oe7dbhnew »
Offline drhex
Usually the output amplifier or frequency switch for ALC and output level errors. Plenty of threads on these errors on the board.
Offline oe7dbhnew
  • Country: at
The message they sent you was:
Hallo,
wie ich gelesen habe, hast du oot Fehler (out of tolerance),
der Fehler 180 kommt immer, sobald eine Kalibrierung fehl schlägt.
Wenn du Preset bei Power ON drückst, wird das Gerät komplett auf default gesetzt und die Calibrierspeicher gelöscht, dann werden einige 300er Fehler auftreten, hier erstmal die Service Keys bis level 2
LEVEL1 -----> 123456
LEVEL2 -----> 250751
der erste Key ist klar zur internen Kalibrierung , bitte führe keine interne Frequenzcal durch, die Speieroutine dafür ist etwas seltsam von R&S umgesetzt, es werden nicht die alten einträge Überschrieben sondern neue anghangen, bis das eeprom voll ist, dann wird es sehr schwierig dir zu helfen.
I made a preset after switching it ON, but now there are more error messages.... below
Not: The batteries have not yet been replaced with new ones.
