Author Topic: Repair help requested for Class D Subwoofer module of 18 inch 1000W amp module  (Read 333 times)
Offline Studi-JoTopic starter
I am 52, mobile DJ, and studied electronics 20 years ago. After that I never practiced.
I have a DB Technologies DVA S10 18 inch subwoofer, 1000 Watts. On my last gig it started to smell....
Decreased volume and had no choice to switch it off.
Once at home I opened the enclosure and found a complete stuck 18 inch subwoofer, this occured the smell.
Ordered a new one and installed it but when I power the active speaker, without any audio input connected, it immediately and always gives a weird sound
It's not a 50 Hz hum but a higher frequency resonance sound so there is also a problem with the amplifier.
I removed the amplifier module "DigiPro 1000S" and opened it. Surprisely the Power Supply Unit is 3/4 of the module and only 1/4 is the amplifier.
Found online the schematics:
https://drive.google.com/file/d/1LB0oHgbkXONhuaymQSkRktFjN_DAph3A/view?usp=sharing
Because I need the subwoofer cabinet soon for other gigs, I ordered a complete new module but it would be nice if I was able to repair the old one and keep it as a spare. Visually I checked ELCO's and power components but nothing seems broken or smells burned.
Started to check the output of the Power Supply Unit:
New: +13,7 VDC (VDD) -13,7 VDC (VSS) -72,7 VDC (-HV) +72,6 VDC (+HV) -59 VDC (VDR)
Old: +13,7 VDC (VDD) -13,7 VDC (VSS) -98,6 VDC (-HV) +98,5 VDC (+HV) -85 VDC (VDR)
Old PSU gives more voltage to the amplifier MOSFETs but I guess this is not an issue.
The PSU seems OK. How to proceed?
The Amplifier has HEXFET Power Mosfets.
Is it possible to check the state good/bad by unsoldering and measuring? I found datasheets from most important components.
Any ideas or step by step instructions how to proceed would be highly appreciated!
Thanks in advance,
Johan
Offline m k
You have now four output channels, so even more comparing options.
For more sophisticated stuff you need a more sophisticated picture.
It's a low frequency stuff, so maybe an old scope is enough.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
