Author Topic: Repair HP ENVY Laptop 17-cg1008ca Motherboard GPT70 LA-J504P  (Read 404 times)
Offline neoOpusTopic starter
I am looking for the schematic of this HP ENVY Laptop 17-cg1008ca Motherboard GPT70 LA-J504P or this component, PQB4 reference (Unable to read the text beyond P5)
I also want to replace these two other parts on the same board, one labelled 43t (if I am not reading it wrong) and another resistor labelled 2R0.
Furthermore, if someone with experience could tell me, why would this component burn in order to avoid this happening again?
And I have a question about modding this mobo in order to have more VRAM, right now, it has two of this chip
Model: H5GC8H24AJR-R2C Brand: Hynix Series:GDDR5 Capacity:8Gb Voltage:1.5V
Which equivalent to 2 GBytes and I want to replace them to get 4 GBytes (to make some AI models work on it).
Thank you.
Offline m k
Re: Repair HP ENVY Laptop 17-cg1008ca Motherboard GPT70 LA-J504P
« Reply #1 on: June 05, 2024, 04:04:41 pm »
Burning 43t and 2R0 is most likely overcurrent.
Three legs of 43t connected, so maybe a source.
Maybe two different voltages through those two equal resistors.
9538 seems to be a battery charger.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
Offline perieanuo
« Reply #2 on: June 05, 2024, 04:23:41 pm »
intersil datasheet may help if you don't get the mobo schematics
Offline fzabkar
« Reply #3 on: June 06, 2024, 02:13:50 am »
« Last Edit: June 06, 2024, 02:54:47 am by fzabkar »
