Author Topic: Repair of 8A pb-battery charger. Unkown part?  (Read 1313 times)
Offline Snake____1Topic starter
  • Country: no
« on: February 25, 2018, 10:12:18 pm »
Good evening people.
I'm at a loss trying to repair a charger. It's based off a switch mode power supply, and output just pulsates. I have checked all diodes, main resistors, optocoupler and more...
I get 350v DC on the main side, but on the secondary side it pulsates up to ~3v...
I have a TO-220 component on the secondary side I can't identify, hope someone can pitch in here... (See photos) "markings are: T410 BV4715 (Google search renders nothing)
Offline 0xfede
Re: Repair of 8A pb-battery charger. Unkown part?
« Reply #1 on: February 25, 2018, 10:31:44 pm »
Hi Snake,
it is an AOT410L from Alpha & Omega semiconductor (100V 150A MOSFET)
You can find the datasheet here:
http://www.aosmd.com/pdfs/datasheet/aot410l.pdf
Best,
0xfede
Semel in anno licet insanire.
  • Country: no
« Reply #3 on: February 25, 2018, 10:45:24 pm »
Thank you @0xfede!
Strange circuitry, seems power goes straight from the SMPS transformer via a relay, to the battery, back through this mosfet and back to the transformer...
Almost seems like they are using the mosfet just for the diode...
Offline 0xfede
« Reply #4 on: February 25, 2018, 11:00:53 pm »
You are welcome.
I can't say for sure if this is the case but MOSFETs are often used as reverse polarity protection. A good texas instruments application note is here:
http://www.ti.com/lit/an/slva139/slva139.pdf
Best,
0xfede
  • Country: no
« Reply #5 on: February 25, 2018, 11:56:44 pm »
Found the faulty component! :) The OP-AMP on the bottom, the LM324. Changed it and now it's fully functional again  :-+
