Hello together,
I'm a new one, so I want to introduce myself a littlebit:
My name is Ben from Germany with a heart for vintage Testequipment. Starting with my first scope, a tek 547 in really bad shape, I now own a really well equipped lab of vintage T&M (Tek most of it, someone will guess I'm a fan...hmm). OK so far, now to my Problem:
It's a few month ago, I got Hands on a rare Tek 568/230 progtammable sampling and automated measurement System. A few words to it. The 568 is mostly like the 561 only with extra connectors for readout and programming. It's normal usage is with the Tek 3S5 and 3T5 programmable sampling plug in Units. With a S4 Sampling Head, it is able to capture risetimes up to 25ps (I only own a S3 with 300ps active sampling probe). You can use it for stand alone, but it is primarily designed to work with a type 230 Digital Unit as an automated measurement System for Amplitude, Time and it's correlation. My issue now is with the 230. A nightmare of discrete, RTL and ECL logic.
A description and the full Manual with schematics, circuit description, etc. you can find here :
http://proxy.w140.com/tekwiki/wiki/230you'll Need the late Manual.
Problem is, that I have the measurement Start and Stop Zones, but I have no Measuement Zone intensification and no readout update on the Nixies. Main start Signal for the measurement cycle is generated on the P9 SYNCHRONIZER board with the Delay Generator, which is controlled with the "VIEW TIME" Knob on the FP. the MEASURE condition is obtained when MEMORIES /CHARGED is LO and the Pulse forming circuit around M1760 is giving a Pulse to M1720 which is the MEASURE FF.
I found out that the Amplitude of the pulse which should latch up this FF is possibly not high enought to do that. The Signal is only near to a Volt, so around 0.8 to 0.9 V (where most other amplitudes are such around 1,6V up to 4V). Becaue I'm not familiar with this type of logic, i can't expect the reason why I have a switching function but as it seems, with to low Amplitude.
I hope someone is out there who is still familiar with RTL and old ECL and can help me with my Problem.
regards
Ben
