Author Topic: Repair of an HP8904A signal generator  (Read 3378 times)
Offline douarddaTopic starter
« on: March 04, 2016, 12:36:46 am »
I have a couple of HP 3904A signal generator. One of them had a failing PSU and I recently took the time to work on it.
I've made a description of the problem and the repair on a small blog I'm beginning there https://whatever.sdfa3.org/hp8904a-multifunction-synthetizer-restoration.html
Long story short, the culprit was a resistor on the small "secondary" board of the PSU (labeled R7, a 20k 1% resistor involved in the current limitation portion of the voltage regulator
I've made a (very) partial schematic of the +16.3V rail of the PSU, if it may help someone:
Now, I have another (small) problem? I've discovered that the 10MHz ref output is flat on the other HP8904A unit. I've begun to probe a bit around the 10MHz output (which is near the 10MHz xtal), and it looks to me the transistor Q106 is dead.
But I cannot find this reference on the net. It looks it's a Motorola, but the numbers (30659) does help so much to find same specs.  Having a couple of other same transistors on the board, I think it's a simple PNP bipolar transistor. I wonder if I can use a basic ref like a 2N3905 instead there.
Anyone have an idea where I can find some specs of this transistor?
BTW, does anyone have the schematic of the A2 (logic) board? It's not in the service manual...
Last edit: PNP, not NPN
« Last Edit: March 06, 2016, 01:37:11 pm by douardda »
Offline SAUL BRITTO
  • Country: br
  • Don't Make a Mistake
Re: Repair of an HP8904A signal generator
« Reply #1 on: March 04, 2016, 01:13:06 am »
Ins't 2n3905 a PNP?
« Last Edit: March 04, 2016, 01:32:54 am by SAUL BRITTO »
Thank You, for all earth.
Offline rf+tech
  • Real radios are olive drab
« Reply #2 on: March 04, 2016, 04:47:53 am »
douardda,
The complete HP part number is 1853-0659, one has to know the proper prefix to prepend to these mysterious part numbers.  :P
The HP-JEDEC cross reference lists this as a 2N3906(SEL), which indicates it is selected for a specific parameter. We have no way of knowing what the selection criteria may have been but I suspect the single digit 3 on the top line might be a clue. Seeing how this transistor sits in a schematic might provide another hint.
For now, pop in whatever 2N3906 happens to be lying about.  :-+
RF+ Tech
RT-1133 AN/PRC-70  *  RT-794 AN/PRC-74  *  RT-841 AN/PRC-77  *  RT-524 AN/VRC-12  *  RT-834 AN/GRC-106  *  RT-F100
Offline brob
« Reply #3 on: March 04, 2016, 04:58:01 am »
It looks like the transistor has a broken wire on the one leg. might be able to patch it back together...
« Reply #4 on: March 05, 2016, 01:31:56 pm »
Ins't 2n3905 a PNP?
Indeed. I've corrected my post. Thanks
« Last Edit: March 05, 2016, 01:38:43 pm by douardda »
« Reply #5 on: March 05, 2016, 01:33:28 pm »
douardda,
The complete HP part number is 1853-0659, one has to know the proper prefix to prepend to these mysterious part numbers. [emoji14]
RF+ Tech
Thanks a lot for pointing me to the  exact reference number.
These  custom part references  are really a pain in the ...
« Last Edit: March 05, 2016, 01:39:32 pm by douardda »
« Reply #6 on: March 05, 2016, 01:38:14 pm »
Amazingly you are right! I did not notice this (impossible to see  it by direct sight, it's obvious on the  macro picture.) I've made a quick fix  by putting a solder drop on the  wire  and my 10MHz signal is back on the  BNC socket.
Thanks
