Hello good people of the blog.
My father is an old mechanic and he had an old battery charger/jump starter it has served him well for almost 30 years but it has now finally broken down, when i turn it on and start to charge a battery it works fine on the two lowest current settings but if you turn it up any higher it snaps the main fuse in the house.. So both me and my father suspect that maybe the inductor inside it is shorting out.. I never tried to repair anything like this or even tried to troubleshoot one of these big inductors so it is a bit scary, anyone got some advice or a place i could start maybe? I opened the thing and took some pictures and the inductor does indeed look burned..
Any advice would be appreciated, thanks in advance!
Best regards from Denmark!
