Hi All,
Finally got my new work bench ready, so I can jump right to the action. I've recently picked up a cheap (and faulty) adjustable power supply. I don't know its exact age, but without a doubt over 20 years old. It a fairly capable unit with a dual 60V 12A output. With such a high power output, you've guessed right, its a switching power supply. Seeing as I have limited experience with similar supplies, figured I'd share here on the forum and ask for the help/guidance of people more experienced with similar circuits.
The problem I'm seeing with this unit, is that right after power up the voltage on channel A start slowly rising (as in 5-10V per second), when it reaches about 10% over the maximum rated voltage of 60V, the unit enters protection mode and shuts off the main part (front panel display is still active as its powered independently). I tried loading it to see what happens then - when loaded with >0.1A it behaves well and the voltage/current limits can be set and are within ~2% of the value read by my DMM. The second channel seems to behave just fine, but its also turned off when the first enters protection mode.
I've had a quick look inside (see pictures attached below) to see if there is something obvious (perhaps minimum load resistors that has gone wrong). I see a couple of 120R power resistors which are connected to the outputs, but they both measure as 120R so they aren't to blame. Other than that I haven't really measured anything just yet. Visual inspection didn't reveal any obvious suspects yet (unless you see something in the pictures which I've missed
While at it I took a few pictures of the working boards too, just as a mini tear-down in case its of any interest to anyone.
There are a couple of (identical, one per channel) boards on the side I haven't taken out yet (one annoying screw that won't budge, I will get it out eventually
). I have taken pictures of these to the best of my ability in their current position. These boards seem to be the heart of the regulator, with a couple of OP400FY's, some 7915/7805/IRF640/BUK436 power MOS and some other devices I can't read the label off.
Let me know if you see anything suspicious or you have some insight as to what I should check first.
BTW, I was unable to find any info on this model on the WWW, but seeing as this is a local Israeli manufacturer of power supply's, I might try shooting them an email just in case - perhaps they could share some info about this unit. I've had used linear supply's from Horizon in the past, like the DHR40-1 which was the first bench power supply in the past. While not as sexy as some other gear, I was always happy with it - it seems like a reliable tool which I can use safely. so I really do hope I'll be able to get it running without keeping a constant load on that faulty channel
Otherwise I'll probably start probing a few points to try and understand where the problem is coming from. "Lucky" for me, the problematic channel has a "grey zone" where for currents of ~0.1A it won't rise indefinitely, but won't go below ~2.5V. This could be used to compare voltages at selected nodes between the working and the problematic channel without a "time limit" of going into protection mode.
