At home our Bosch induction cooktop became unresponsive to the power on button, in the last week of it's two year warranty. Fortunately I was able to arrange to be there when the repairman came, and replacement of the display / touch panel solved the immediate problem.
It's not an uncommon fault for one or more of the buttons to stop working or be intermittent in operation, according to the repair person. I asked if I could keep the old board to have a look at it, which was fine, because "no one can fix those mate!"
The board is fairly involved and has touch pads, the led displays, a control microcontroller and a sounder. It is made by EGO, and apparently is common to a whole swathe of other European brands, including Gaggenau, Neff, and possibly Smeg as well.
Inspection revealed that the touch pads connect via a resistor into the inputs of HC4053 chips, a triple 2 channel analog multiplexer. There is no external protection for ESD for the conductive pads which sit below the glass cook surface, although the HC4053 has protection internally.
Replacement of the 74HC4053 associated with the power switch restored functionality, so now we have a service spare board should the fault arise again. I also replaced the HC4053 IC associated with element selection, as this had been unreliable for most of the life of the appliance, although not annoying enough to warrant a service callout.
Hopefully this will be of help to other EE's in an out of warranty predicament.
