If it works, hey ho, stop right there. Cut the tracks and be done with it.
Unless you can find the exact right encoder, you're taking a gamble. Even if the stepping is correct, the bounciness of the encoder may be totally different than the one that was spec'd.
This problem with Ersa is disheartening. I am starting to feel like every mechanical encoder is destined for failure. I think the only thing I own where this hasn't happened are my digital scopes. And that may be due to how frequently I use them.
I'm pretty sure an encoder emulator utilizing up and down buttons is in my future. So I can fix things like my Korad power supply once and for good. 3.2, 3.3, 3.4, 3.5, 3.0... 3.2, 3.3, 3.4, 3.5, 3.0...
