Found Heuer LG11 Level Generator 200 Hz to 4000 Hz in the skip at work a while ago
http://www.heuer.com.au/tmsa11/lg11.htmlIt was little beaten up, scratched missing the battery holder and door. Some had attacked the torx screws with a hacksaw so they could use a flat bladed screwdriver.
It comprises three board. The front panel has display and other controls processor card and the output card
After pulling it apart you could see that the batteries must have leaked at some stage. Replaced the battery connector and replaced 4 AA battery holder
Made a new battery compartment door from a blank PCB
From the specs
FrequencyRange30 Hz to 20 kHz
Resolution1 Hz:30 Hz to 1 kHz10 Hz:1 kHz to 20 kHz
Spot Frequencies200 Hz, 300 Hz, 400 Hz, 600 Hz, 820 Hz, 1020Hz, 1200 Hz, 1600 Hz, 1800 Hz, 2000 Hz, 2400Hz, 2700 Hz, 3000 Hz, 3400 Hz, 4000 Hz
