I recently acquired an HP3437A system voltmeter through eBay. Not because of need, but because of cheap (and curiosity).
Interesting piece of equipment. Aside from the mediocre specs (nowadays even regading speed, its main selling point back in the day), it seems to be a model with relatively few info out there.
Of course, it was non functional. When configured for 1 reading in the 10V range it seems to work. However, increasing the number of readings or changing the range, the displays shows 9999 and the ignore trigger LED lights up.
So far, I've just checked the test points in the analog board and everything seems to be okay. I will start going through the manual. At a first quick reading I'm suspecting the optocouplers but nothing concrete so far.
I attach a few pictures. More will follow soon.
A few interesting tidbits: both input connectors (input and rear) are triaxial connectors (I wonder, if I sold those would I recover the 60 euros spent in the unit?
). Also very nice is the way the boards unfold and make testing a relatively simple matter.
