Thanks for the tip ..
I actually desolderd al the "moves" and mesured them .. all good .
Progress so far :
Replaced :
Top224 ( broken )
3 TVS diodes ( SMCJ170A )
1 bridge rectifier ( was still ok i guess )
1 47uf Tantalium ( close the top224 ) wasn't dead
1 BAS21LT3G ( was broken in secundairy .. cracked )
1 CNY17-4 ( opcoupler ..)
1 BYW4200B ( diode accros secundairy caps .. shorted ! )
Now it's partitaly alive .. the 3V rail seems ok .. other rails are to low .. and the sound of the inductor or smsp sounds not 'normal"
If i measure before smsp is measure 80volts .. on the out put ( across capacitors ) only 16 volts dc .. ( capacitors are rated 63 volt and in series .. so i think voltage should be higher .. )
I think this is to low ..other voltages required higher ..
VCC3
VCC5
VCC20
VEE65
VEE40
It's getting compilcated now
don't know where to look now.
Especially w/o schematic ..
