Author Topic: Repair of SDS2104  (Read 449 times)
Offline gregfox151@gmail.comTopic starter
Repair of SDS2104
« on: November 20, 2024, 09:16:28 pm »
Hi all, My Channel 1 went flatline on this SDS2104, all the others are ok(2-4).
I found this Cap to be open when removed and was hoping someone would know what the value is.
Many Thanks!
« Last Edit: November 20, 2024, 09:30:54 pm by gregfox151@gmail.com »
Offline KG7AMV
  • Rhine_Labs
    • My Personal Blog
Re: Repair of SDS2104
« Reply #1 on: November 20, 2024, 09:56:56 pm »
I would just pull one from another channel and measure it.
« Reply #2 on: November 20, 2024, 10:02:15 pm »
thanks for the reply, not so easy, I almost pulled the pad on this one and would hate to screw up another channel.
Offline Harry_22
« Reply #3 on: November 20, 2024, 10:13:55 pm »
Tweezers are needed. Or simply add Rose alloy and blow hot air.
« Reply #4 on: November 21, 2024, 11:02:46 pm »
It will be that awful lead free solder so dilute it some with leaded solder.
Check what the cap connects to and if it's a power rail to the IC's it's likely local bulk storage or decoupling so a 10uF MLCC might be a substitute but pull another to check.
« Reply #5 on: November 25, 2024, 10:46:38 pm »
 :)  It seems the problem was solved simply by pressing the default button! It wasn't the Cap at all.
