I'm trying to fix the psu above..
The low power part of the psu (fairly simply flyback circuit) is constantly restarting due to what I believe is the psu thinking there is an overcurrent problem..
I've attached the schematic for the low power part of the psu (psu_lo.png)..
If I put a resistive load on the + or -7V outputs (150ohm), there's no problem, but as soon as the output for driving the hi power part of the psu (through D23) is enabled and loaded (e.g. with a 1kohm resistor - the unloaded voltage of this output is ~15V), it tries to restart approx once per second..
All the diodes seem to check out, and the electrolytic caps also don't appear to be much off in capacitance or esr.
I've changed C28 and C22 (and also D22 in case it should be leaky) but that didn't make a difference.
I can't find what model the switching controller is.. it's marked what looks like 32A18.. the 2 could be a 7, the 8 a B. I've tried to reverse engineer the pinout (see IC3.png). The switching frequency seems to be ~750Hz when the circuit is unloaded (i.e. D23 removed, and nothing connected to CN3). The frequency rises with load on +-7V outputs, but the gate pulse width stays the same (~1.4us), indicating this isn't a pwm controller?
What confuses me is that the +-7V outputs seem to work fine, but the third one going to D23 immediately triggers (what I think is) the overcurrent protection set by R19 (2.0 ohm) when enabled by connecting STB to +7V. This should indicate that the problem is on the secondary side of the transformer, but but only with the output going through D23?
Loading directly on C28 +, bypassing Q1/Q2, makes no difference.
Has anyone got any ideas to why only the output going through D23 seems to cause trouble, and/or what the switching controller chip model could be?
