Author Topic: Repair of stick welder, can't find suitable IGBT replacement  (Read 1769 times)
Offline Snake____1Topic starter
  • Country: no
« on: November 27, 2018, 12:21:24 am »
Hello,
My stick welder stopped working and I have narrowed it down to the IGBT module pack, problem is I can't find any replacement or even datasheet for that matter. I have attached an image of the IGBT module, the only number I can get any hits of is: P280B57.
Can anyone here help a fellow DIY'er out?
Re: Repair of stick welder, can't find suitable IGBT replacement
« Reply #1 on: November 27, 2018, 01:52:25 am »
Can you do a pic of the pin out please ?
Offline coromonadalix
« Reply #2 on: November 27, 2018, 05:26:53 am »
model and brand name may help too, be more descriptive  thks
Offline Housedad
« Reply #3 on: November 27, 2018, 06:27:48 am »
It looks a whole lot like a Vincotech part, but that part number did not come up.  I agree.  What maker of welder?  Age? Tig, mig, or stick?  Declared amperage  of welder?
At least I'm still older than my test equipment
  • Country: no
« Reply #4 on: November 30, 2018, 11:33:58 pm »
Pinout is all over the place, the dismantling of the IGBT pack was more or less destructive as I had to snip the pins. Some of the pins came lose from the IGBT pack and was left on the PCB...
It may be a TYCO P280B57 part, hard to get a hold of a retailer. This is a stick "MMA" welder, Fronius TP1100. Maximum 110A.
Offline PaulAm
« Reply #5 on: December 01, 2018, 12:26:58 am »
There's a listing on Alibaba for that, might be worth a chance if nothing else turns up.
