I have several Tektronix TDS540 scopes, all have had the leaky capacitors replaced, washed, and checked for defective connections. The remaining problems are varied and I have located on-line the following Tektronix document: Tektronix part number 070-8313-00, THE TDS520 DIGITIZING OSCILLOSCOPE, Component Level Repair Manual, Volume 2. This document contains complete schematics for all circuits, and a large number of trouble shooting flow charts that refer to diagnostic tests. For example, one flow chart starts with "Run the cpuBusCtrlReg diagnostic". Does anyone know................
1-. Is Volume 1 of this document available?
2.- How does one perform these diagnostic tests? Are they part of some testing software that one runs when connected to the Console Port? If so, is this test software available?
The information given in Volume 2 is of limited value without access to the diagnostic test software, or some way to invoke the tests? Any further information will be greatly appreciated.................Thanks
