xrunner, you're doing a good job making me want to start down this road.
Come on in the TM500 pool - the water's fine. (that is of course after you have repaired the entire pool filtering system
I pulled the two resistors, as shown on the schematic they are 10 ohm rated @ .25 W. burnt to a crisp. One measures 24 ohms the other is an open. I also pulled the two output transistors - Q540 and Q542. As you can see in the pic they look like they got overheated BUT they test OK in the transistor checker with an hFE of 137 and 145 respectively. I cross referenced them as follows according to the Tektronix part number on the case -
Q540 - 151-0103 --> NPN 2N2219A
Q542 - 151-0134 --> PNP 2N2905A These are very common transistors so even though they check out I'm going to replace them, they may misbehave at high temperatures. Also will replace the resistors of course but I'm going to go with a .5 W size just for good measure. Have to order these parts. I ordered plenty of these transistors in case the previous stages require replacement. Also will provide socket pins too because I don't want to stress this old board out with any more heat in that area, as you can see they appear to have been replaced at least once already.
I have inspected the entire area; with a mirror I can see underneath Q530 & Q532 and do not see signs of overheating, also junctions read properly so I don't think these are bad. Next will go backwards and make sure the incoming waveforms are being generated properly prior to entering the output stage.
So guys any speculation as to what happened? Remember people do some very dumb things with test equipment up to and including connecting the output of one unit
into the output of another ...
