I put the TM501 chassis away for now and tried the PG501 in my spare TM504 - the light is still not on but it does output a positive pulse - but not a negative pulse. However, the positive pulse output seems to work very well. I attached a pic of a 15 ns pulse. Although that missing negative output bugs me right now, I decided to go for the low-hanging fruit today.
So remember the phrase "The lights are on but nobody is home"? We have to reverse that "Somebody is home but the light is not on".
OK, well what have we here - a failed LED? NO! We have a burnt out lamp!
Yes, this has a factory original grain of wheat bulb with a green lens - not an LED. The original parts list specifies a 5V lamp rated at 60 mA. So we have that along with a 270 ohm r to limit the current since it's on the -18V bus. That surprises me because all the other units I have now use LEDs. Is anyone aware of any other TM500 series units with bulbs?
The bulb is hung off the -18VDC supply through a 270 ohm current limiting resistor, so I decided to go ahead and convert it to an LED (although I could have kept it original since I have some of these bulbs). I decided to use a clear white LED and keep the original green lens. I just removed it and glued it on the white LED. It has a nice green light with that lens on it.
Now the light is on and somebody is home. More to come ...
For new players reading that need to know how to do an LED retrofit:
The white LED has a ~3.2V drop at 20 mA. To calculate the required current limiting resistor -
18V - 3.2V = 14.8V (voltage drop of the current limiting resistor)
14.8V / .02 = 740 ohms (required current limiting resistor for 20 mA)
We already have a 270 ohm resistor on the circuit board that the lamp used, so in theory we could just add another resistor of about 740 - 270 = 470 ohms. However, I felt that the LED would be too bright @ 20 mA, so I added an extra resistor of 750 ohms. Total resistance is then 270 + 750 = 1020 ohms which allows a current of 14.5 mA. Also, in this case remember to connect the cathode of the LED to -18V and the anode to ground.
