Hi Guys, newby here so please be gentle! Just starting in electronics. If info stated isn't enough pls confirm what additional info is needed.
Have a 240v transformer with regulated voltage output of 5v, 7.5v, 12v etc dc. (little 'arrow' component turned via screwdriver).
It went kaput a while ago and took along to the Maker shed and changed an input resistor and hey-presto all good, seemed to work.
When I got home thought I'd check the output voltages and all seemed to correspond to stated DC voltage. May be odd but I also tested on with multimeter set to AC voltage and it was reading around double the DC voltage. Then tested for Hz and at initial switch on it it was reading 50Hz for about 2 seconds, then going to zero. This seemsed wrong.
Checked a pc regulated voltage supply and no such Hz reading, which is what I would expect.
Any idea where I should start with fault-finding?
