I'm in the middle of repairing a device, a TSP controller. I'm still kind of running diagnostics on it to make sure that it wasn't anything external, but I wanted to ask a question about fuses and how devices work at different input voltages.
This device I'm trying to fix has two input settings: one for 220 V and one for 120 V. The 220 V setting requires the use of 8A fuses while the 120 V setting uses 15A fuses, so depending on the input setting, you have to change out the fuses. If it was set to 220 V while not changing out fuses correctly, so you would be using the 15A fuse, would it still work? The fuses just cut the circuit if the amperage of the fuse goes too high, but it's not a catch-all, right? If it was connected to a power strip (220 V with a 10 A fuse), I would think that the 10 A power strip fuse would break first before the 15A fuse, but is that always the case?
