Yes just apply a little sticky flux, and melt the solder again, and it will work, unless the terminal itself has cracked. Will not do much change except for possibly 1mR change. If terminal is broken you will need to replace it, easiest to use the ground terminal below, and use it in place of the existing one, as the terminal type is the same, and the broken one will still work as ground, as the insulators stay in position there.
