Author Topic: Help Repair Rigol DG1022  (Read 679 times)
Offline Giovanni62Topic starter
« on: April 13, 2021, 05:08:08 pm »
My Rigol DG1022 function generator, the CH channel stopped working; no output signal. The self-test does not give errors. I noticed that by selecting the CH2 output, when I change the waveform you can hear the relays working, instead when the CH1 output is selected, the relays do not work when I change the waveform type. Any suggestions?
« Last Edit: April 13, 2021, 08:27:11 pm by Giovanni62 »
