I find that People don't like reading large text. Want to skip the maintenance process and know the result directly.
I know it saves time. ( I enjoy the thinking process.it's fun. Sometimes like a detective.)
So I go straight to the juice.
There are two really fatal failures. deadly failures.
1.A4 source board has NO source signal output
2.A5 receiver A R R* trace are always below -10dB
Causes of A4 board failure is U80 Located on the back of the PCB board.
It is a general purpose amplifier. The model is MSA-0386 marked A03. Amplifier input is open circuit.
Receiver failures are much more dramatic. There is a capacitor short circuit in the + 5V circuit that powers the PCM-78P AD converter.
After I simply removed the capacitor, The miracle happened.
I will continue to revise this post to clearly describe the maintenance process.
The Following Is What I Wrote Before.
Recently I got a faulty Agilent 8714ES.
It cost me 3,500 chinese yuan. It's about 3500/6.8 = 514 dollars.
It came from a bankrupt antenna factory. (Many factories are closed now in China)
But I'm worried that it's made up of several faulty boards of different instruments.
In fact, my worries are not unreasonable.
A label on the instrument says "Receiver failure".
But now the instrument self-test shows the bus communication fault.
Over the next period of time, I will try to repair this 8714es.
The keysightsite does not provide a detailed service manual.
So I know that such maintenance will be difficult.
But I'm not totally blind either.
Because I had an 8714et, and it works normal.
These two instruments are basically the same.So I still have a reference.
It may take a long time, because I still have a two-month-old baby to look after.
