Had to change the dilithium crystals
Bingo, we have a winner.
PedroDaGr8 wins a prize - bunch of hi-res photos!
I did not disassemble much, as I feel not comfortable messing with high-frequency stuff which I don't understand
So at this moment, just a repair photo set, not a teardown.
And since now I can use my repaired camera to make timelapses, made one for R&S SMT03 battery fix as well.
4K UHD resolution for detail
Ok, here are those pesky high-resolution slow-loading photos again...
Front panel have nice soft-feel buttons and enormous size display (as for generator). Front display glass is metallized to shield internals as well!
And no, it's not touch.
Unit is pretty heavy and bulky, but short
Back have some coax connectors, RS232, GPIB and two medium noise fans.
Let's turn it on to see what's wrong..
Aha, looks like it have sick battery, just like old 7000-series TDSes from Tektronix...
Self diags agree to that..
Let's crack it open and try to fix..
Nice robust chassis, modular construction. Well made, very clean and tidy design. There are empty slots for options. My unit is just basic configuration,
so have lots of emptyness
Bottom side shows us backplane interconnect with few bodged wires ( not me , promise ).
Output unit is 3GHz marked. All modules shielded from both sides and have coaxes running in and out.
Main output is routed via rigid coax with SMA ports.
Output attenuator. It clicks a lot when changing output in big steps
More coax stuff..
And main output, totally separate from front panel body/assembly.
It's type N 50 ohm female type.
But our suspect is not in high-frequency area/boards. Where is usually battery located? In digital processor area, near SRAM. And where is processor board?
It's not here, it's on front panel module. So I will not touch any of that high frequency boards and go right after front panel..
Uncrew 4 corners and here we have, solid metal shielded block with front panel, screen and digital board. Really easy to service.
Take a look at attention to details. Even 2.54mm headers have special plastic locks to secure connection!
Or rubber pads on ribbon cables entry holes on shield to prevent cutting cable by metal edge. Never see such things before!
Remove back shield:
Ahaaa
Delithium crystal detected, blue thingy bottom right near CPU
Which is Intel i960. Not a common guest in test equipment, I'd say.
Some more chips with funny names, like comgate, orbit...
And some ADI stuff
Ok, let's check battery voltage...
0.93V, no good!
Desolder batt of the board.
Have nice cutout and standoffs for easy servicing. Jumper nearby connects positive terminal to board. Well thought!
Battery itself (this photo is actually of original battery which I replaced when just got a unit):
Solder new battery in and voltage check:
Now assemble everything back and check.
Unit boots fine, run self-diags:
OK!
OK!
Battery passed and OK now.
All errors and calibration was restored by unprotecting PROT1 LEVEL via entry of password "123456" and running VCO,FM calibration steps. All this is performed by internal operation,
no need external calibrators or connections.
And some information about unit:
No errors in this system:
So back in business
