Author Topic: Repair tips for 500W Audio Amp  (Read 1246 times)
Offline gjhTopic starter
« on: August 29, 2023, 05:36:08 am »
Any tips for repairing the following Audio Amp - https://www.megamusiconline.com.au/product/behringer-eurolive-vq1500d-15-inch-powered-pa-subwoofer-500-watt/
It seems to be melting the ground wire between the onboard AC socket and PCB before blowing the fuse.     Dont really see anything obvious inside besides a bulging electrolytic cap.   I guess one of the amp/power transitors  could be gone drawing more current.    It's been awhile since I did circuit theory in school.     Apart of purchasing a thermo camera (something Im thinking about for home leak detection)  whats the best way to troubleshoot ?
« Last Edit: August 29, 2023, 05:43:48 am by gjh »
Online Messtechniker
Re: Repair tips for 500W Audio Amp
« Reply #1 on: August 29, 2023, 06:06:07 am »
1.) Measure each capacitor in-circuit.
2.) Extract those which do not measure OK in-circuit.
3.) The replace those which do not measure OK out of circuit.
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
The following users thanked this post: gjh
« Reply #2 on: August 29, 2023, 06:46:00 am »
Will give that a go.    I have a ESR Meter as well :)
Offline mengfei
  • Country: ph
« Reply #3 on: August 29, 2023, 07:41:15 am »
Isolate & Test
Isolate the Power supply section from the AMP & the test the supply alone then you can go from there
for power amps usually it's the output or power supply problem. Sometimes some relays gets stuck too
take it out of the metal casing & just check the PCBA making sure that there is adequate GND
« Reply #4 on: August 29, 2023, 12:37:55 pm »
When testing power supplies on their own,
dont forget that some will need a load. :horse:
Offline knudsenuk
« Reply #5 on: August 31, 2023, 01:46:25 pm »
Agree, isolate the psu first, emulate the psu with a bench psu (with current limiting) connected to the amplifier module and also measure the DC offset on the output which I suspect will be skewed heavily in favor of one supply rail, giving you an indication of the likely failure, also one rail will be drawing much more current from the supply. Obviously if it is a genuine 500w then it it may be hard to the operating voltage from a bench psu.
