Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Resin dipped axial capacitor identification
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Resin dipped axial capacitor identification (Read 754 times)
Snake____1
Contributor
Country:
on:
June 06, 2019, 03:29:02 pm »
Hi everyone,
I have a board in for repair, it's an old style with all through-hole components. I am used to SMD work so the markings on the capacitors were Greek to me.
Does anyone have a link for a deciphering table or know the value of the capacitors attached?
Logged
capt bullshot
Super Contributor
Country:
Re: Resin dipped axial capacitor identification
Reply #1 on:
June 06, 2019, 04:38:09 pm »
I'm slightly confused, but following the standard decoding rule this would be 74 * 10e-1 -> 7.4pF
So it't the 7.4pF that makes me doubt the result since this isn't a standard value.
Logged
PKTKS
Super Contributor
Country:
Reply #2 on:
June 06, 2019, 05:07:18 pm »
These form factors appears in devices intermediate from THT to SMT
IN general they CAN BE ANYTHING: RESISTOR/INDUCTOR/CAPACITOR/MOV/NTC
The figure is not showing the silk screen which I GUESS IS "Cxx" something
but even being C the label is not very common and markings are very odd
really they are close to SMD fabs with AXIAL leads...
VHS systems from 90xx use to have a lot of these... DIODOES/RESISTORS/CAPS
Markings are pretty much the same nightmare of SMD things...
vast majority requires a considerable time to decipher
Paul
Logged
Snake____1
Contributor
Country:
Reply #3 on:
June 06, 2019, 08:06:58 pm »
These have the C107 + C108 etc. markings on the silkscreen. I measured a couple others on the same board, they read out everything from 74nF to 88nF. So deffinatley scratching my head... Are they supposed to be 74nf according to markings?
BTW, thanks for the inputs so far...
Logged
coromonadalix
Super Contributor
Country:
Reply #4 on:
June 06, 2019, 09:04:48 pm »
I would guess a tons of 0.1 uf, in thoses times they did put lots of them, around your blue 34 pins connector, they are decoupling caps.
Do you have an lcr meter ?? capacitance meter ??
Logged
floobydust
Super Contributor
Country:
Reply #5 on:
June 06, 2019, 09:29:04 pm »
OMG Q17 was hit by a truck, why are you worried about those capacitors. I doubt they are your problem.
They look like old AVX ceramic capacitors, I thought they have two rows of numbers series and value. Never seen them fail.
Tantalum C76 would be worth checking.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
