> floobydust: ..not sure about technique on servicing live mains-powered equipment...
well, I've repaired TVs, laptops/computers and 12v/5v devices (routers, etc, you name it), they are all 'live mains powered'. But usually they step it down a notch with some kind of transformer.
(or as with Tv's the problem is more obvious by optical inspection)
In this case, I don't have much to go on.
Yea, want to buy my own isolated Variac, I used to lend it, because I so rarely need it, I don't repair that much anymore, but its so handy to have available.
Any recommendations on ebay or otherwise on that?
I've measured the triac, using this method:
http://www.completepowerelectronics.com/how-to-test-triac-with-multimeter/ it seems ok. the BTA312 was not available to me locally, so I will order it if I get nowhere.
>floobydust/Seekonk: check 1: run the motor alone with a series lightbulb
>floobydust: check 2: measure MCU power across ZD1
>Seekonk/SeanB: I have a 'The blue ESR meter', so I can check the ESR on the caps and capacitance with a multimeter.
Seekonk: which ones are 'X2' caps? I'm not familiar with that term?
I will do some measurements and lets see where that gets me.
Otherwise I will replace the caps and zener as SeanB said.
