Author Topic: Repairing a Bicycle battery  (Read 678 times)
Offline fantTopic starter
« on: July 01, 2024, 02:57:53 pm »
Good morning;
I am trying to repair a BMS for a bicycle battery where a component is missing.
Anybody has the same board so to know the characteristics of the component or at least a datasheet of the protecting IC (OZ7714CN)?
The open voltage of the battery is 48V, but no power on output.
 Thank you in advance
Offline Greybeard
Re: Repairing a Bicycle battery
« Reply #1 on: July 02, 2024, 12:12:45 pm »
Datasheet:
http://www.o2micro.com/products/O2%20807&G807C%20Product%20Catalog%202023-6-26(final).pdf
Problem:
Your IC is SOIC24, datasheet shows QFN28, so pin numbers are not matching.
« Last Edit: July 02, 2024, 12:40:59 pm by Greybeard »
« Reply #2 on: July 02, 2024, 09:12:05 pm »
Good morning;
thank you for the link, but I had already seen it and discarded due to the pin count difference.
I can find some spare on aliexpress, but before changing it, I would like to make some circuit investigation.
 Anyway, again thank you for the search and time spent.
If anybody has new info, will be very appreciated
Best regards
Offline indeterminate
« Reply #3 on: July 03, 2024, 12:31:16 am »
At a wild guess it will be the Bat 1 pin of the ic so the missing component will be another 100 ohm resister
« Reply #4 on: July 03, 2024, 08:15:34 pm »
Thank you "indeterminate".
I did it, but it begun to heat up.
Tested, the voltage difference between pins is 3,7 - 3,8 V (probably the firs element of the battery pack), so I've tried with a 0,1 uF and second test with a 1 nF capacitor, but no result.
I am beginning to think that that it is locked into the anti-theft function, even if the battery belongs to a friend of mine and therefore I know that the origin is legal and he assured me that there is no switch or key on the battery for this function.
Continuing to dig.
Thanks to everybody
Offline Greybeard
« Reply #5 on: July 04, 2024, 08:12:34 am »
This photo may help you (arrow doesn't mean anything):
https://electrotransport.ru/index.php?topic=5439.msg2302542#msg2302542
I would not invest much time and energy to find the root cause of your problem, I'd just buy a new BMS PCB.
« Last Edit: July 04, 2024, 08:17:17 am by Greybeard »
« Reply #6 on: July 06, 2024, 04:23:44 pm »
I made some more test, but no result.
So, probably I will buy a new BMS.
The deadline is Tuesday, If I will not fix it, I will change BMS.
Thank you to everybody for the suggestions and help.
Mandi
