Hello,
I hope someone here has a good eye and can tell me what model this FCP connector is and where to source it. It is severely bent off the PCB and while the multimeter tells me the pins still connect through it doesn't seem to work anymore.
Searching on Element14 and Mouser I haven't found anything that looks like it matches.
The component is marked SJ16 and the board is marked GR001_ESS_EL_MainBoard.
See attached picture - thanks in advance!
