I got a Yamaha HTR-5840 Amplifier which I got off a friend, and its definitely past its use by date and an issue has occurred with it. I am not sure whenever this would be a simple fix or not, but I just want to give it a try because its still working and I am pleased with it otherwise I'll just have to salvage the parts and throw it out.
Basically the problem is that it sometimes doesn't want to turn on, this has only started happening recently. I turn the amp off using the mains switch and not the standby button (it still uses electricity in standby mode). Anyways when I turn it on it turns on, but if I were to turn it off at the mains and then turn it on again it wouldn't turn on. It would work after a few hours or so, but not straight after. Sometimes just playing around with the switch works, but thats time consuming.
A month back it had the same problem, but I cleaned it on the inside with a vacuum cleaner and then it began working, however then it began to develop the same problem soon afterwards. I am assuming maybe there is a bad capacitor or something inside of it and it would be just a simple fix of replacing that cap and we got a working amp again. Or perhaps there is a cold solder joint there...
Any ideas what is going on with this amp?
