Author Topic: Repairing a Keithley 197  (Read 1038 times)
Offline ZachreyTopic starter
« on: June 09, 2020, 12:44:52 am »
Please help!
I just got a Keithley 197A from a seller on eBay.com and it is clearly defective! The seller will not take a return so I may have to try and fix this bugger! I have a little bit of experience with this and only have an oscilloscope and a multimeter to work with. Here is a Youtube video of what the unit is doing. Do you think there is any hope?
https://youtu.be/6OrLtb9O-co
Thanks!
Zac
Offline Wytnucls
Re: Repairing a Keithley 197
« Reply #1 on: June 09, 2020, 08:27:08 am »
Here is the maintenance manual with schematics:
https://doc.xdevs.com/docs/Keithley/197/197_901_01A.pdf
Offline tooki
« Reply #2 on: June 09, 2020, 04:04:42 pm »
One thing to check is the FETs that perform the range switching.
As for it switching to dB, that’s not a default for any mode, so perhaps there’s contamination on the display PCB, which the dB button lives on, causing it to detect a spurious press of the button. Give those contacts a clean. Oh yeah, and see if there’s any difference with the backlight on or off — the high voltage supply for the EL panel is also on that PCB. I don’t know if they have any failure mode that could cause noise, but it’s easy enough to test so why not! :)
P.S. it’s not good form to hijack an existing thread for a new question, even if it’s about the same model. It’s better to start a new thread.
« Last Edit: June 09, 2020, 04:06:15 pm by tooki »
Offline akabek
« Reply #3 on: February 02, 2021, 10:33:20 pm »
Yesterday I received a Keithley 197a I purchased from ebay.  I took a gamble as it was listed as parts and not working.  Today I plugged it in and the screen was showing OL and the range buttons including auto would not lock in place after pressing a button.  I found a couple of repair videos on You Tube that I reviewed.   I took that cover off and removed all boards so I could look over the components.  Everything seemed OK except the buttons would not stay in when pushed.  I applied Deoxit 5 followed by Deoxit gold.  I waited 15 minutes and reassembled it.  I connected a DC power supply and tested a resister and it is working now.  With the wierd things going on I would not have thought cleaning the controls would make that much of a difference but give it a go.
Offline Ordinaryman1971
« Reply #4 on: February 03, 2021, 05:39:10 pm »
I think it's a great advice, clean the switches first. Deoxit is great, exercise them after applying the Deoxit and try to take measurements again.
Offline akabek
« Reply #5 on: February 03, 2021, 06:13:35 pm »
My unit was doing a lot of weird stuff.  After reviewing YT videos with similar oddities  that were corrected with Deoxit I am a firm believer in the product.  Right after doing a visual inspection of the components I would go right to cleaning and lubing switches and dials with Deoxit.
« Last Edit: February 04, 2021, 02:09:10 pm by akabek »
