During my lunch break this afternoon I had a chance to to crack open the scope and remove the power supply board. I inspected it for bulging/leaking caps and I checked all of the diodes using my meter, and all looked good. This thing is stuffed with Rubycon caps, so I doubt any of them are faulty.
I then powered it up on the bench without the rest of the scope attached (I removed the main ribbon cable as well as the cables for the fan and the backlight). After pressing the power switch I could hear the board "chirping" in the same pattern as the fan was turning on and off when it was still connected to the board. By "chirping" I mean I hear the switching supply starting up and shutting back off again.
I am getting energized capacitors on the secondary side of the switching transformer, but without any reference for what the voltages should be I'm just stumbling around in the dark. I did measure low resistance across the secondaries of the power supply (around half an ohm, give or take), but this did not concern me much knowing that the only resistance would be that of the winding itself. Regardless, I removed the transformer from the board and measured the resistance directly across the windings. I also measured the resistance at the pads. I measured the same low resistance across the secondaries of the transformer, and open circuits/high resistance on the PCB, so the secondaries do not appear to be shorted on the PCB.
To confirm that the transformer was working, I then connected the transformer to my function generator set to output a 150kHz 0-10V square wave (similar to what I expect the circuit does on the board, based on the application circuit for the TOP246YN off-line switch) and probed the secondaries with the scope. The primary-to-secondary ratios appear to be around 5:1 and 7:1, though I don't know how accurate these measurements were. I was guessing on the frequency. Anyway, assuming rectified US mains being switched across the transformer I expect this to result in (roughly) 34V and 24V on the secondaries. Unfortunately I am not able to get an accurate measurement of these values because the supply switches off before the output caps can become fully energized, so any measurements would not be accurate.
That's about where I left off. I plan to work on this a little more during the weekend, but I'm not quite sure where to go next. Any suggestions?
I will see about posting photos a bit later.
Thanks,
Matt
