Author Topic: Repairing a modern LED house light?  (Read 2844 times)
Offline e100Topic starter
« on: January 11, 2014, 10:02:26 am »
Has anyone attempted to dismantle, repair and reassemble one of the new generation of brand name LED lights?
I purchased a 6W "Osram parathon CL A 25" which died after only 2 months of use, so presumably the power supply circuitry has failed. No smoke or bang, it just stopped working.
http://www.svetila.com/en/light-bulbs-lamps-66/led-lamps-990/led-parathom-classic-25-fr-6w-ww-6241.html
There things aren't exactly cheap so I would like to attempt a repair, although it isn't obvious how you pull it apart without destroying it. It's a 4 piece construction - semi-transparent dome which appears to be glass or some kind of hard plastic, a metal heatsink (aluminium or zinc?), a plastic ring then the contact assembly with screw thread.
It's a 240V bulb so the repair and reassembly will need to be done with safety in mind. If that is too difficult, then I'll convert it for use with 12v.
Mike
Online Psi
Re: Repairing a modern LED house light?
« Reply #1 on: January 11, 2014, 10:05:53 am »
This page at least shows what's inside http://slenderloris.synthasite.com/parathom.php
Sadly it doesn't have any pics that show how it comes apart.
« Reply #2 on: January 11, 2014, 10:19:35 am »
Here's a pic of similar bulb which perhaps suggests that the dome pulls off somehow.
http://www.led-professional.com/technology/light-generation/osram-applies-201cbrilliant-mix201d-led-concept-to-parathom-pro-classic-a-80-led-lamp-and-prevaled-system
On mine there's no room to put a screwdriver or wedge between the dome and the heatsink.
« Reply #3 on: January 11, 2014, 11:16:29 am »
It is a potted assembly, and you sadly will find it hard to take apart. the ES base can come off to expose half the power board, but they were never designed to come apart.
Offline TheWelly888
« Reply #4 on: January 11, 2014, 12:01:34 pm »
It died after 2 months of use - it should be still under warranty so take it back to the shop and get a refund or replacement!
Don't bother to faff around repairing the thing!
You can do anything with the right attitude and a hammer.
Online kripton2035
« Reply #5 on: January 11, 2014, 01:38:56 pm »
++++1
