Author Topic: Repairing a Rocktron GAP v1 - Replacement fuse  (Read 293 times)
Offline alderfc7Topic starter
« on: August 19, 2024, 09:24:45 pm »
I have been working on an old Guitar preamp Rocktron GAP v1 (model of 1990 I think). These had issues with the Voltage regulators and caps blowing due to heat since they are next to the transformer.
I have replaced the regulators and caps and looks like the fuse is also blown. I need some help identifying the right resistible fuse to replace it  with (It's the first time I encounter such fuse).
As I understand this is a 500Ohm 1/2Watt fuse (the rating of the preamp is 22Watt which aligns with a 500Ohm resistor).
Can I have some help confirming it and get maybe some suggestions on replacement options? :)
Thank you in advance!  :)
Offline David_AVD
Re: Repairing a Rocktron GAP v1 - Replacement fuse
« Reply #1 on: August 20, 2024, 08:54:17 am »
It's a 500mA fuse, not a resistor. The rating (1/2 Amp) is written on the PCB.
The following users thanked this post: Manolo Mos
« Reply #2 on: August 20, 2024, 06:11:21 pm »
thanks for the help!yeap, i can confirm it's a 500mA fuse. first time i come across.
