Author Topic: Wanted: Hameg HM8122 frequency counter EPROM image.  (Read 256 times)
Offline BreakingOhmsLaw
  • Certified solder fume addict
« on: April 01, 2021, 12:14:20 pm »
Hello,
I am restoring a HM8122 with massive overvoltage damage. A complete and utter trainwreck, nearly every chip is dead or damaged.
Does anyone have an HM8122 frequency counter and would be kind enough to read the EPROM for me?
It's socketed by default, so it just requires removing a few screws to open it up and pluck it from the PCB.
V4.1 would be great, but I guess any version will do.
Your help is appreciated!
Offline poppniete
Re: Wanted: Hameg HM8122 frequency counter EPROM image.
« Reply #1 on: April 17, 2021, 05:50:34 pm »
Here you go. As you can see, it is a rev. 4.1 firmware:
[attach=2]
The whole firmware fits in only 8 kB memory - amazing.
Good luck with your repair.
Regards
Jan
The following users thanked this post: coromonadalix, rob040, shakalnokturn
« Reply #2 on: April 17, 2021, 07:07:58 pm »
Many Thanks!
Offline rob040
« Reply #3 on: June 02, 2021, 05:12:06 pm »
Is V4.1 the latest ever used by Hameg?
