Author Topic: Repairing a Rusted Chip  (Read 6637 times)
Offline Bashstreet
Re: Repairing a Rusted Chip
« Reply #25 on: August 16, 2018, 10:30:05 pm »
what a mess, that's what happens when pcb's are left covered in flux.
the tin-plating / tin in the solder has rusted because moisture has become trapped in the flux.
Tin do not rust  :-DD
Offline stj
« Reply #26 on: August 17, 2018, 01:21:07 am »
yes it does.
you must be pretty young to have never seen a rusty tin can before they switched to aluminium.
even so, you should have seen rusted pins on leadfree soldering that was dumped outdoors.
Offline helius
« Reply #27 on: August 17, 2018, 03:30:10 am »
Tin is an expensive metal. When canning was originally developed in the early 1800s, steel was rolled with tin to make tinplate. The cans were not ever made of solid tin—that is absurd.
If you really believe that cans were made from solid tin, you should go out and buy all the razor blades you can, since they say they are platinum.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #28 on: August 17, 2018, 06:02:49 pm »
Tin corrodes as well as any other metal, though it's not usually called "rust".  Tin is rarely used pure, almost always as a plating.   Copper has an oxide that may be confused with rust.
Seven Transistor Labs, LLC
Offline james_s
« Reply #29 on: August 17, 2018, 06:53:27 pm »
As far as I know, "rust" refers only to iron oxide, but oxygen is a very reactive element and most metals will oxidize readily. The biggest difference is in the properties of the oxide. Iron oxide crumbles and falls off exposing fresh iron which then oxidizes and this is what happens when something rusts away. Aluminum oxidizes more readily than iron but aluminum oxide sticks quite firmly to the surface forming a barrier that protects the metal below. I don't know as much about the properties of tin oxides but I know they will form.
Offline Bashstreet
« Reply #30 on: August 18, 2018, 12:30:55 am »
yes it does.
No Tin do not Rust
The cans are not pure tin it would be too expensive and pure tin is too soft.
They are just tin plated soon as tin gets knocked, way to the iron/steel is exposed and they rust out  :palm:
« Last Edit: August 18, 2018, 12:35:01 am by Bashstreet »
Offline stj
« Reply #31 on: August 18, 2018, 05:17:14 pm »
so why does lead-free soldering rust???
Offline james_s
« Reply #32 on: August 18, 2018, 05:57:24 pm »
If it rusts then it must have iron in it. I don't recall ever seeing solder rust but I suppose there could be an alloy with iron, or maybe the flux resembles rust?
Offline Bashstreet
« Reply #33 on: August 19, 2018, 12:14:28 am »
No idea ? why would anyone add iron on solder.
I have never witnessed such solder nor seen it sold  ???
« Last Edit: August 19, 2018, 12:25:27 am by Bashstreet »
Offline KL27x
« Reply #34 on: August 19, 2018, 12:35:49 am »
I would guess the iron is in the chips. And that additionally, these boards were soldered with a water soluble flux containing ammonium/zinc chloride. It's probably the steel in the lead frame producing the rust, and the epoxy case of the IC was not adequate to seal it from chloride ions and air getting in there. So tinning can't cover the steel and stop the rust, because it is leaking out from where the pins come out of the epoxy. It's maybe older encasing tech or some failure in processing that damaged the epoxy.
If OP could not buy new chips, I would remove them all, clean the flux residue thoroughly, and dunk them in any acid but HCl to eat away any rust. Rinse in water and dry with alcohol. Dunno how many chips that is. It's certainly a lot of work. But mechanically removing the visible rust probably can't stop the source of the problem. This probably can't either, but it theoretically has a chance... of slowing future problem. If the chips are already acting funny, it's probably too late. It's not just presence of rust you can see, but there is maybe rust in the chip pushing on and breaking the wire bonds.
If you can buy new chips I bet you have no problem in the future, provided you are using halide-free flux. I would wash the FPC thoroughly in hot water and a brush before putting on the new chips. I imagine they would be a horror show on the inside, already, by the time rust is pushed out of the chip.
* scratch all that.
If you have device(s) that still work, I'd clean what I can see with a fiberglass brush, then coat thoroughly with some suitable lacquer/paint to slow any more oxygen from getting into the chip.
I have some PCB I soldered with plumber's flux. Maybe this will happen to them in 30 years.  :-//
« Last Edit: August 19, 2018, 01:28:49 am by KL27x »
Offline PKTKS
  • Country: br
« Reply #35 on: August 19, 2018, 05:15:07 pm »
Nobody said the most plain solution which BTW I have done
a lot with decent results.
I just clean what is possible (the  just metallic dust part) with ISOPROPANOL
As the chip may be very fragile a soft brush in a strong solution should do.
Then if not wasted completely I would cover the parts with SOLDER MASK (UV curable)
with some thin tip a portable UV.
The really wasted parts I would consider a JUMPER  -  really not that hard w/today
tools and optical assist. And BTW I would use LEADED solder.
LEAD-FREE profile is just too complicated to bond that crappy left overs.
It usually works cheap and easy
Paul
Offline Bashstreet
« Reply #36 on: August 19, 2018, 08:39:45 pm »
Has been recommended by many.
Unless the rust is neutralized it will continue corroding under the solder mask as it has bonded with sufficient oxygen.
Using leaded solder to rework lead free boards is wrong way to go.
Use lead free solder to repair lead free boards  :popcorn:
Cheers.
« Last Edit: August 19, 2018, 08:55:37 pm by Bashstreet »
Offline helius
« Reply #37 on: August 20, 2018, 07:32:49 am »
A device made in 1986 is very unlikely to use lead-free anything.
But in general, unless there is a very good reason, rework should use leaded solder no matter what the factory used. It makes better, more consistent joints, removes the risk of tin whiskers, and avoids unnecessary thermal stress to the board and components.
Offline VK5RC
« Reply #38 on: August 20, 2018, 10:36:39 am »
Have those leads corroded right through? - looking at the photo - it appears as though something is joining the pins - perhaps rust but other oxides possible - do you have access to a fibreglass pencil brush? If you do, wear gloves, sealing safety goggles and work outdoors - little bits of fibreglass in you fingers take weeks to come out (don't ask) - can't imagine what would happen if you got some in your eye. :scared:
Offline PKTKS
  • Country: br
« Reply #39 on: August 20, 2018, 11:15:17 am »
Once properly covered the amount of corrosion will be very low.
If you manage to clean enough a still usable part the protection cover will last
last enough to not worry for a long period.
The tip on LEAD-FREE is just to make that sure that by some convenient
you pick the wrong solder.  LEAD-FREE today is as common as LEADED
IMHO  for hand soldering BENCH REPAIR - LEADED just works better
LEAD-FREE or paste are very specifics.
In that case I would do all in LEADED with a very very minimum temp
to avoid stressing the corroded parts. They will get worst (worse?!) with the heat...
Paul
« Last Edit: August 20, 2018, 11:17:21 am by PKTKS »
Offline Bashstreet
« Reply #40 on: August 22, 2018, 05:04:42 am »
It is better repair lead free boards with lead free solder as it is not good idea to mix alloys and different melting temperatures can cause bonding issues.
You can repair lead free boards with leaded but as guide it is better use same alloys.
Modern lead free solders are very good and there is not need to continue using leaded solders except to repair very old equipment or in special circumstances where leaded solder will be required.
Some people seem be very fond of their leaded solders that's fine but times move on and no point get too nostalgic about solder :-//
« Last Edit: August 22, 2018, 05:23:25 am by Bashstreet »
Offline james_s
« Reply #41 on: August 22, 2018, 05:39:01 am »
I haven't found a lead-free solder that works as well as the standard tin-lead stuff. With good old 60:40 rosin core I get nice clean shiny joints every time.
Offline KL27x
« Reply #42 on: August 22, 2018, 06:09:58 am »
There are several very different lead-free alloys. Without knowing what alloy and what flux has been used on a board, do u still rather use any random lead free? Im asking, not judging. I am jot voting, here, but I have been reworking lead free boards with leaded, and I'm curious, now.
Through the years, several new products have hit the market. Is there even a standard lead free alloy, today? With leaded you are talking a few percent here, maybe a dash of silver. pretty much it.
« Last Edit: August 22, 2018, 06:12:00 am by KL27x »
Offline PKTKS
  • Country: br
« Reply #43 on: August 22, 2018, 11:44:52 am »
Neither do I.
For repairing rusted or oxidized parts LEAD-FREE just can't do it
A good tin bond requires plain LEADED and 99% cases I use a flux
proper to OXIDIZED MATERIAL - not the regular "normal" flux.
The thing i use has several drawbacks:
- contains AMONIA - very crappy smoke fume
- it is HIGHLY CONDUCTIVE and if not properly cleaned it will left conductive residues.
But it works like nothing more. It justifies the drawbacks.
Once applied it will  VANISH all corroded material and BOND the LEAD SOLDER almost
perfectly in minimum time. It works but there are drawbacks using the stuff....
Normally this flux is used in HIGH THERMAL mass chassis and parts. Not micro-soldering
But i haven't found anything that works near close that ...
for rusted oxidized parts. No matter how bad the rust
the crappy flux vanish and bond the tin like magic.
« Last Edit: August 22, 2018, 12:00:01 pm by PKTKS »
