Author Topic: [Fixed] - Repairing a Samsung 940BF  (Read 2753 times)
Offline raul
  • Country: pt
« on: September 12, 2016, 08:49:48 pm »
Hi
I'm repairing a power supply (CCFL inverter circuit) of a Samsung 940BF monitor.
I change some caps and a fuse (probably works by now) but i don’t know what is the chip P610 CD6F14 (No luck with google (pt)). This chip have the paths a little baked.
Thanks
« Last Edit: September 15, 2016, 12:03:48 pm by raul »
Offline TheBay
  • Country: wales
Re: Repairing a Samsung 940BF
« Reply #1 on: September 12, 2016, 08:59:14 pm »
The following users thanked this post: raul
Online wraper
  • Country: lv
« Reply #2 on: September 12, 2016, 09:05:49 pm »
This is normal, those mosfets run quiet hot and with time PCB darkens in most of the monitors.
Offline raul
  • Country: pt
« Reply #3 on: September 12, 2016, 09:28:13 pm »
Here you go:
it's a AOP610.
http://aosmd.com/pdfs/datasheet/AOP610.pdf
Thanks @TheBay. I Will save that and test this chip before i put everything together. Weird, i couldn't find the brand.
Probably should change that IC before burnout. If i can find one similar. Thanks
Offline TheBay
  • Country: wales
« Reply #4 on: September 12, 2016, 09:31:10 pm »
Here you go:
it's a AOP610.
If the monitor is working leave that IC, as Wraper said that's normal.
From looking at the images that's hardly got that warm, I have seen much much worse :)
Online wraper
  • Country: lv
« Reply #5 on: September 12, 2016, 09:41:31 pm »
BTW, if it does not work after replacing the capacitors, check secondary winding of the CCFL transformers, should measure around 1k.
Offline raul
  • Country: pt
« Reply #6 on: September 12, 2016, 10:34:08 pm »
Thats useful. Thanks
Offline raul
  • Country: pt
Re: [Fixed] - Repairing a Samsung 940BF
« Reply #7 on: September 15, 2016, 12:09:31 pm »
Hi
Apparently is fixed. I'm shore it has the pico fuse 3A that connects to the inverter part (main power supply and the inverter power supply is in the same board but placed in different part) if the motive of a blown fuse are in other side don't know i change some fat caps in the process... will see.
Thanks for the intel.
