Hello everyone,
so I have laid my hands on a somewhat older monitor (Samsung SyncMaster 943NW) which has started having issues turning on. I cracked it open and found two caps which were visibly swollen - a pair of 470 μF 16 V Su'scon SG caps. I went to a local electronic components store and bought the closest replacements I could've found - 470 μF 35 V Samwha RD caps.
Now, Samwha RD caps are quite close to the Su'scon SGs when it comes to maximum ripple current and impedance (that's the same as ESR, right?), but are they close enough? Values provided in the table below. Ideally I'd like the ripple current to be higher than that of Su'scons and the impedance lower, but unfortunately neither is the case.
| Capacitor | Maximum ripple current ([mA], rms, 105°C, 100 kHz) | Impedance ([Ω], 20°C, 100 kHz) | Impedance ([Ω], 20°C, 120 Hz) |
| Su'scon SG 470 μF 16 V | 1030 | 0.053 | 0.2821 |
| Samwha RD 470 μF 35 V | 911.75 | 0.0742 | 0.3951 |
Another option which came to my mind is to order a pair of capacitors from a more reputable brand, and perhaps more suitable specs, from somewhere nearby, but I'm concerned I might get duds or counterfeits. Wouldn't be the first time I saw counterfeit parts in legitimate supply chains. Now, is there an affordable way to ensure they are in the ballpark of a genuine, working part, say by measuring them with a tool like MESR-100?
Best regards,
apheon
1 approximated based on tan δ formula (tan δ / (2πfC))
2 approximated proportionally from Su'scon ratio between impedance value at 100 kHz and value derived from tan δ at 120 Hz
